Clipboard manager at the quick find shortcuts!
Will be good if also clipboard manger be at the Quick find shortcuts menu it is possible?
There are two ways to access Clipboard history in FastKeys:
- using a Clipboard shortcut defined in Preferences/Clipboard Manager (default Ctrl+Shift+V)
- using a Clipboard Manager Toolbar - open it by right clicking FastKeys tray icon.
It is also possible to insert various clipboard items into the text phrases - use Insert Data/Clipboard macros.
