it just plain stops working. then I reload it and it's fine for a while.
it's getting really annoying. may have to find something else.
have to reload the app several times each day
Is is it just Text Expander or other modules stop working as well? Could it be that your run some conflicting applications?
We can check if you use any specific commands which might cause the issue - you can send us your settings.fdb and settings.ini files for testing.
