Text expander with Mbutton
When i set button "Mbutoon" to shown me suggestion of my texts, but when i try to chose my texts it does not choose it! ( i mean left button of mouse ) Only if i typing my string then i can chose it and it successfully inserted in the input field by my left butoon of mouse . How to set also left buton when i only press my Mbutton?
I'm not sure I understand but I tried this and it works as expected:
Shortcut: Mbutton
Type: Send
Command:
Check if you are using some other shortcuts which may interfere.
Shortcut: Mbutton
Type: Send
Command:
First selection
/Second selectionthank you very much but i think you must record video waht you whant to sad me or how its works... Im not sad exactrly asked waht you say me i think)
- marcelolima
you probably have more than one command for the same shortcut. Have you already done this check?
