lowercase letters are changed to CAPITAL
sometimes [happens suddenly] Fastkeys when executing text-expander or a gesture to run a webpage,
instead of typing https://www.fastkeysautomation.com/forum/, Fastkeys writes https://www.fastkeysautomation.com/FORUM/
"the last bit of the address is changed to capital for no reason"
and in loading webpages i get an error to open the page because of this issue [page doesn't exist or some other message]
when i reload Fastkeys, everything returns to normal.
Please advise.
Please advise.
The majority of the problems like this is related to underlying Windows systems/processes. We tried to add some internal controls in the most recent version of the software, which version do you use?
Also, check if you are using some special scripts or shortcuts which may cause this. Do you use a standard gesture key?
am using v5.07
Also, check if you are using some special scripts or shortcuts which may cause this. = not using scripts for this related issue and no shortcuts
am using a standard gesture
Is this a Type Run or Send?
What is your gesture key?
Send
gesture = UR
gesture = UR
I mean gesture key in Preferences/Gestures? RButton?
MButton
If this will continue please contact our user support.
