izeppelin
Post
by izeppelin » Feb 11th, ’22, 09:24
Hi folks!
I'm trying to create a macro that sends ```cursor here``` however, since ` is an escape character it's not allowing me to send it directly. I've tried escaping the escape character but I simply can't send all three.
This is to simplify markdown syntax
Post
by Marko » Feb 11th, ’22, 09:31
Escaping the escape character works for me:
`````` shows three characters.
kmaustral
Post
by kmaustral » Sep 10th, ’23, 22:12
Thanks for the advice. This works, but it leaves an excess of grave accents below:
I'm using this in Obsidian. Did you find the same issue?
kmaustral
Post
by kmaustral » Sep 10th, ’23, 22:17
For future reference, I found this works better if "Use clipboard" is selected.
