Executing shortcuts from cmd
jamiep87
Post by jamiep87 » Nov 23rd, ’21, 03:15
I am using a Stream Deck from Elgato. It's basically a macro keypad. Are there any plans for the future to launch a shortcut in FK using a command line? So I can create a button on my keypad to open that shortcut when tapped. I can currently accomplish this using hotkeys and have the stream deck execute that hot key but using a command should eliminate coming up with free hotkeys.
Post by Marko » Nov 24th, ’21, 18:18
This means FastKeys would first need to run (reload) before executing the listed parameters - there would be a short delay.
But it is certainly possible to implement it in one of the next releases.
