FastKeys 5.01 Released
Post by Marko » Feb 14th, ’21, 10:16
What's new in FastKeys 5.01:
14th February 2021
Release notes:
- Updated translations: German, French, Italian, Chinese, Hindi, Slovak, Norwegian, Slovenian;
- Small improvements and bug fixes.
Special thanks to Jürgen Feldmann, Patrick Eder, Markus Jungwirth, Nico, tfr, 梦幻のFF, Abdul Tauhid, Marián Hikaník, Ronny Oretap and TWaits.
Comments, suggestions and bug reports are highly appreciated as they help us to continuously improve. Thanks! :)
Download FastKeys HERE.
gustms
Post by gustms » Feb 14th, ’21, 18:35
Thank you!
GapsOfTheGod
Post by GapsOfTheGod » Feb 22nd, ’21, 08:09
Despite being met with a message this morning that v5.01 was available, and that none of my settings would be lost, I've lost every one of my, roughly, 150 Text Expansion phrases and shortcuts. I've created a forum account just to express my sheer disappointment, as I'd hoped to purchase the software, but not sure a purchase is justifiable after this.
Post by Marko » Feb 22nd, ’21, 08:20
Sorry for your experience but none of your settings are lost.
If you have upgraded from version 4 then version 5 is installed in parallel and is not overwriting any settings. You can still run version 4. Version 5 should offer the automatic import of settings.
Please contact our support mail to receive more detailed support for your case.
GapsOfTheGod
Post by GapsOfTheGod » Feb 22nd, ’21, 14:32
Thanks, however I'm running the portable version and there appears to be no other exe file, other than the version which opens v5.01. Where will I find my phrases from v4 please?
Post by Marko » Feb 22nd, ’21, 20:30
Your old settings file must be located in your FastKeys/Data folder - use File/Open to load it.
If this doesn't work try loading the data from the backup:
Use File/Open to select one of the recent backups from "Documents\FastKeys\FastKeys Backup" folder.
Then use File/Save as... to save the file with another name to "Documents\FastKeys" folder.
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Feb 23rd, ’21, 04:08
Thank you.
