I see the possibility to change the theme colors for the gui. But is it possible make a custom theme? That would be great...
FastKeys 5 color themes
Hi, thanks for the upgrade, looks very nice. I particularly like the ability to customize the icons on edit screens.
Yes, you can.
To create a custom theme in FastKeys 5
- go to C:\Users\%UserName%\AppData\Roaming\FastKeys folder,
- open Current.fktheme file,
- edit the the color definitions in the file,
- save the file with a different name.
To select a newly created color theme
- open FastKeys,
- select a theme in Preferences/General.
Hope this helps. If you create something nice, please post it in the forum.
- open FastKeys,
Wow, great!!! So I'm able to make my own color scheme...
averebazmadar
I am glad to hear this, because if I choose Dark theme, it remains light. Although how can I set the right panel's font color? I don't see "ColorFontRight" option and if I add it, nothing happens. So with a real dark theme I can't read what is happening there
Currently the possibilities are limited, you cannot change the font color on the right.
