Gestures in opus
davidp
Post by davidp » Nov 24th, ’20, 09:14
How to create a gesture work in directory opus(a file manager) for going back and forward,pls tell step by step.
Post by Marko » Nov 24th, ’20, 11:51
Are there keyboard or mouse shortcuts available for back and forward? If yes, you can simulate them.
davidp
Post by davidp » Nov 24th, ’20, 15:13
yes,the keyboard shortcut's are alt+left arrow for going back and alt+right arrow for going forward,so how ?
Post by Marko » Nov 25th, ’20, 19:22
Try the following:
{Alt Down}{Left}{Alt Up}
and
{Alt Down}{Right}{Alt Up}
davidp
Post by davidp » Nov 26th, ’20, 05:19
should I create a left gesture in default and use the above command,what should i use in type and window ?
Post by Marko » Nov 27th, ’20, 16:44
Create two gestures, Type: Send.
You can restrict it to only work in Opus - you can find the window name using Tools/Window Information Tool.
davidp
Post by davidp » Nov 28th, ’20, 07:49
should i use the "title" of the window information tool in window of the fk's
Post by Marko » Nov 28th, ’20, 08:36
Yes.
davidp
Post by davidp » Nov 28th, ’20, 08:47
ok,i did it as u said,but it's not working ,pls tell an other cmd.
Post by Marko » Nov 28th, ’20, 18:57
You must be doing something wrong. Please post your exact settings.
