popup box?
GSD
Post by GSD » Sep 20th, ’20, 17:23
New user.
When I have 1 text expander entry, a popup box (presumably for multiple choices) appears with just the one entry in it. Is there a say to just execute the entry without the box appearing, since there is only one option to enter?
Thanks,
Jerry
Post by Tom » Sep 20th, ’20, 18:14
You have probably enabled the "Manual confirmation" option when setting the text expander.
GSD
Post by GSD » Sep 21st, ’20, 14:30
Yes, that was it. Thank you, very much.
