Requests: Shortcode inside "Start Menu Module" + Icon for the Parent Menu
chm
Post by chm » Sep 2nd, ’20, 23:51
Hi Dev Team,
Firstly, thank you for your magnificent software.
I have two suggestions/requests:
1- Please add the ability to directly create shortcuts for apps added into "Start Menu Module", so we do not have to repeat the same entry in "Shortcuts Module".
2- Please an option so that we can assign an icon to the parent menu. Example: I have a menu called "Browsers", that contains sub-elements (that are some browsers...). I want to add an icon before the "Browsers" word.
Thank you
Post by Marko » Sep 6th, ’20, 18:50
Thanks for your suggestions, we will put to the list for possible future development. ;)
1 - You can copy the command contents, create another item and paste. There is also "Copy to start menu" option.
chm
Post by chm » Sep 8th, ’20, 19:02
Marko wrote:
Sep 6th, ’20, 18:50
Thank you for the reply !
