Spectacular Start menu designed in FastKeys - can you beat this?
Toolbar settings are available in Preferences/Start menu - More settings.
Go to Preferences/Start menu/More settings and change the Mode to "Icon and text right".
- marcelolima
Would it be possible to make available the .fdb of this menu and the settings file?
I'm trying to edit something like it, bus without success.
Thank you so much.
Best Regards,
Marcelo.
I don't have the file. But what's the trouble? It's a standard Start Menu - Use Properties/Start menu - More settings for the background and general settings and ... (three dots) button for individual settings (icon and color).
- marcelolima
The problem is that I don't know how you entered different colors for some items as was done in the example.
Another thing that I haven't identified how to do and more important to me is to put the sub-items as titles of a topic (this one highlighted above).
To change the color of the individual menu item, select the ... button next to the Menu entry field - here you can change the color, style and the icon. I guess the title menu items were created as dummy items (Type Run with a dummy path).
CeciliaCopeland
How cool is it that you did that, I had no idea that with FastKeys combinations you can work so well on the Start Menu, thanks for the idea, I will try that now.
- marcelolima
I feel the FastKeys user community is begging and clamoring for the Master Tom to make the above template available.
