Curious if Fastkeys can do this...
Post by Marko » Mar 8th, ’25, 11:22
"Tree" in the list resulted in endless loop. Try this:
InputBox, Word,, Word,,, 130
InputBox, ListE,, Comma delimited list,,, 130
List:=[]
loop, parse, ListE, `,
	List[A_Index]:=A_LoopField
send, ^c
sleep 100
text:=clipboard
stringreplace, text, text, `r,, all
stringreplace, text, text, %word%, ♥, all
while InStr(text, "♥")
	Random, selected, 1, List.maxindex()
	stringreplace, text, text, ♥, % List[selected]
sendinput % text
travibe
Post by travibe » Mar 8th, ’25, 12:20
is that heart symbol supposed to be in there or did some text get mutated?
travibe
Post by travibe » Mar 8th, ’25, 23:38
Ok, i have the clipboard rewriting a bunch of text which is amazing progress from nothing happeneing before. Only issue i'm having is it gets aboout 2 paragraphs written then the text starts getting all jumbled up and my computer starts acting strange (I believe the clipbaord is typing too fast and the letters are then being turned into commnads outside of the text editor?) What values do you suggest for the clipboard settings in Fastkeys? I currently have it set at
