Spectacular Start menu designed in FastKeys - can you beat this?
Oblomov
Post by Oblomov » Mar 7th, ’21, 17:45
Marko wrote: Mar 7th, ’21, 15:23 Well, in Start Menu you can only have one submenu level so for a thousand of entries, the menu would quickly become too large to fit on screen.
You should keep using Quick find where you can also search etc.
Indeed, just regret that I didn't utilize it from the start, since like 70% of all my commands in Shortcuts are basically only for Quick Find 😔
augustosabeh
Post by augustosabeh » Mar 19th, ’21, 12:53
heyy awesome!!
Please send us the instructions to be able to do it :D :D
thinman
Post by thinman » May 10th, ’21, 19:35
This is stunning! I also checked the latest video tutorial on start menus and a whole new world opened to me.
So many great ideas, impressed, thanks!
Post by Marko » Jun 29th, ’21, 08:28
Bob Mainguy
Post by Bob Mainguy » Jul 26th, ’22, 13:34
Hello
I'm just starting out with Fastkeys and a menu like this would work great for me. I've been experimenting a little with Start Menus and was wondering if this was done with a "menu" or "toolbar". If this is a Toolbar, how are the columns created? I think a Toolbar could be useful in a case like this but I'm can't figure out how to format it like this.
P.S.: I'm hoping someone is still monitoring this older post :)
Post by Marko » Jul 28th, ’22, 17:34
This was made using a regular “Menu”, using Split by columns option.
Bob Mainguy
Post by Bob Mainguy » Jul 28th, ’22, 18:21
Thanks for getting back to me. This is what I had thought and started building on my end.
anjelinus
Post by anjelinus » Nov 9th, ’22, 10:15
I'm also using a bigger menu, but my menu splits automatically after the ninth menu item. It doesn't matter which order I place the items and if I use a seperator or not. Is this a bug?
Post by Tom » Nov 9th, ’22, 20:27
Difficult to say, I suggest you contact our support mail.
AndreF
Post by AndreF » Feb 14th, ’23, 23:23
Sorry to necro this, but the text in my toolbar menu is aligned to the center of the button, not the left as in the opening post. How can I change this?
