Cycle through windows with mouse
davidp
Post by davidp » Jan 1st, ’19, 03:51
Write a script to cycle through opened windows(as how Alt+tab works) with recently used first,using mouse's right click and the wheel.
Post by Tom » Jan 2nd, ’19, 11:03
Shortcut: ~RButton & WheelDown
Command: Send, !{Esc}
Shortcut: ~RButton & WheelUp
Command: Send, +!{Esc}
Double-click on a shortcut field to enter advanced shortcuts.
davidp
Post by davidp » Jan 2nd, ’19, 15:34
Which module and what should i enter for other fields? Tell me step by step.
Post by Tom » Jan 2nd, ’19, 19:30
Select Shortcuts module and add two new shortcuts:
Shortcut: double click on the field and enter: ~RButton & WheelDown
Description: Next window
Type: Command
Shortcut: double click on the field and enter: ~RButton & WheelUp
Description: Previous window
Type: Command
Command: Send, !+{Esc}
davidp
Post by davidp » Jan 3rd, ’19, 03:49
It's cycling only in the taskbar and the window is not opened on what i cycle also wheel up is not working and context menu is getting opened
Post by Tom » Jan 3rd, ’19, 10:38
I updated the post for both shortcuts. It works for me in Win7 and Win10.
It's the same as pressing Alt+Esc and Shift+Alt+Esc on a keyboard, can you try that?
