Fractions command
burque505
Post by burque505 » Apr 8th, ’17, 17:13
Hi, this is my first visit. I'm trying out FastKeys. I'm an utter novice at AutoHotkey also, but I'm already getting some mileage out of it.
This little script, which is from an AHK script I use a lot, shows there's more than one way to show a menu for selections. Here, from the "Text Expander" tab on the menu, I use Insert->New for a new entry. I use "Command" as the Type for the Substitute, and "Trigger immediately" in Options.
The string I use to trigger it is ;fractions, the first reason being obvious and the second just because I like to start my strings with a semicolon (reason being that in normal typing there will always be a space after the semicolon).
Please note I've changed my "Separator" in Settings from the default to "|".
As you'll notice, you can get a completely different menu by replacing or adding entries, between the "|" separators or after the last "|" separator of course, in line:
TextMenu("¼|½|¾|⅓|⅔|⅕|⅖|⅗|⅘|⅙|⅚|⅛|⅜|⅝|⅞")
Return
TextMenu(TextOptions)
 StringSplit, MenuItems, TextOptions , `|
 Loop %MenuItems0%
   Item := MenuItems%A_Index%
   Menu, MyMenu, add, %Item%, MenuAction
 Menu, MyMenu, Show
 Menu, MyMenu, DeleteAll
MenuAction:
SendInput %A_ThisMenuItem%{Raw}%A_EndChar%
Return
I hope this may be useful to somebody.
Thanks for the program, Marko, I'll register soon unless I come across some deal-breaker.
thinman
Post by thinman » Apr 11th, ’17, 07:05
Great idea, this will be very useful for me. Thanks!
burque505
Post by burque505 » Apr 12th, ’17, 21:19
Thanks, thinman, that's encouraging! :D
