Open a website,when i place the cursor at the top right....
davidp
Post by davidp » Jun 24th, ’18, 17:24
How to open a website,when i place the cursor at the top right of the display for a few milliseconds?
Post by Marko » Jun 25th, ’18, 16:53
You need to run this script on startup. Create a new Start Menu item with Run on Startup option. Type: Command.
CoordMode Mouse, Screen
SetTimer, CheckMouse, 500
CheckMouse:
MouseGetPos, x, y
if (x > A_ScreenWidth - 2) and (y < 2) and not WinExist(winname)
	RunWait, Notepad
	WinGetText, winname, A
Return
davidp
Post by davidp » Jun 26th, ’18, 11:05
How to open google with it? and what should i enter in the menu and submenu field ?
Post by Marko » Jun 26th, ’18, 13:33
Something like this? You can enter anything for Menu and Submenu fields. For more details, please contact us on our support mail.
CheckMouse:
MouseGetPos, x, y
if (x >= A_ScreenWidth - 2) and (y < 2) and not WinExist("ahk_class " winname)
	Run, www.google.com
	sleep 2000
	WinGetClass, winname, A
Return
davidp
Post by davidp » Oct 10th, ’18, 14:38
Will you add this function to the UI ?,because it's not working when firefox is already opened.
Post by Marko » Oct 11th, ’18, 18:33
No, sorry, this was just a demonstration of what FastKeys can do.
