Disable window movement
gustms
Post by gustms » Jul 25th, ’15, 02:58
Hello Marko or somebody else who knows AHK, could you please give me a help?
I found this excellent code which prevents the movement of a window. The problem is, it works by, when enabled, use the combinations of Win+f2 to activate, and Win+f3 to deactivate. But I want it to work just like the "Make Window Transparent" and "Windows always on Top +" in a way that, if I press the shortcut, it will activate and disable movement, and if I press again, it will deactivate and enable movement of that window. Is it possible?
Thanks a lot in advance.
#F2::DisableMove()
#F3::RedrawSysMenu()
DisableMove(hWnd="") {
If hWnd=
   hWnd:=WinExist("A")
hSysMenu:=DllCall("GetSystemMenu","Int",hWnd,"Int",FALSE)
DllCall("RemoveMenu","Int",hSysMenu,"UInt",1,"Uint",0x400)
DllCall("DrawMenuBar","Int",hWnd)
Return ""
RedrawSysMenu(hWnd="") {
If hWnd=
   hWnd:=WinExist("A")
DllCall("GetSystemMenu","Int",hWnd,"Int",TRUE)
Return ""
Source: http://www.autohotkey.com/board/topic/2 ... -a-window/
gustms
Post by gustms » Jul 25th, ’15, 03:33
Update:
I got it! Based on the "Make Window Transparent" and "Windows always on top +" examples. Is it okay this way, or do you think it could be improved?
Thanks in advance.
WinGetTitle, Name, A
If (SubStr(Name, 1, 1) = "#") {
Name:=Name := SubStr(Name, 3)
RedrawSysMenu()
else {
Name:="# " . Name ;chr(134)
DisableMove()
WinSetTitle, A, , %Name%
If hWnd=
   hWnd:=WinExist("A")
Return ""
If hWnd=
   hWnd:=WinExist("A")
Return ""
Post by Marko » Jul 25th, ’15, 13:02
Hi Gustms,
This is a good method if you need a frozen window marked with # character. You could make it even simpler by just toggling a dedicated variable on/off - see an example in the first few lines of Show/Hide Clock command.
gustms
Post by gustms » Jul 25th, ’15, 15:34
Thank you Marko. I like it marked with a symbol, just like Always on Top, and Transparent (which I added a symbol as well). I think I'm gonna keep it as it is.
If someone is interested, the example from the second post seems to be working just fine on my tests.
theone1
Post by theone1 » Dec 12th, ’16, 07:00
great scripts guys, thanks!
