Endless mouse
Ennovy
Post by Ennovy » Apr 11th, ’14, 20:46
I have a script that reads mouse position every 1/2 second
When the mouse reaches the end of the screen, the cursor will be moved to the beginning of the screen and vice versa.
This simulates and endless mouse.
When I test the script it works fine.
I want to start it when FK starts and stop it when FK is closed.
This is what I tried (but doesn't work):
New Start Menu entry
Menu: Mouse
Submenu: Endless Mouse
Type: Command
Options: Run on startup
Command:
#Persistent
CoordMode, Mouse, Screen
SetTimer, ClosePopup, 500
ClosePopup:
MouseGetPos, xpos, ypos
IfGreater, xpos, 1918 ; my screen with is 1920 pixels
	MouseMove, -1918, 0, 0, R
IfLess, xpos, 1
	MouseMove, 1918, 0, 0, R
;IfLess, ypos, 1
;	MouseMove, 0, 1078, 0, R
My script also has options to close, move resize certain windows when they are created or activated.
Or automatically click the OK button in some windows etc etc.
For now I want to focus on this endless mouse feature.
So the script needs to stay resident. Can this be done with FK
Thanks Marko
Post by Marko » Apr 12th, ’14, 20:42
Ennovy, great idea. There was a tiny bug in the "Run on Startup" routine which was now corrected. You can download and re-install and it should work.
Ennovy
Post by Ennovy » Apr 12th, ’14, 20:53
Great software AND support!
Now it works fine, thanks very much Marko
Guest
Post by Guest » Sep 14th, ’14, 23:29
Cool idea, thanks for this useful command, just what I needed. :D
Ennovy
Post by Ennovy » Sep 15th, ’14, 08:43
Glad you like it :D
Ennovy
Post by Ennovy » Jan 7th, ’15, 10:28
The script stopped working and the
#Persistent
command is now displayed in red :roll:
Is this command no longer valid or is there some bug introduced in the latest version?
Post by Marko » Jan 7th, ’15, 12:06
Nothing wrong with the script, also the syntax coloring is still the same.
What I see is that submenus with "Run on startup" option are not displayed correctly. This will be resolved in a next release. Until then you can put the script to first level menu.
Ennovy
Post by Ennovy » Jan 7th, ’15, 13:42
The script IS in the first level menu :)
Now I know how it started:
Yesterday I created a second start menu, to be activated with a hotkey.
I removed the second start menu and everything works fine again. So it must be a bug in FK
Post by Marko » Jan 8th, ’15, 07:28
Thanks Ennovy., will be resolved.
TokyoMike
Post by TokyoMike » Mar 12th, ’19, 14:23
I am wondering if there is an easy way to change this to somehow allow me to switch resolutions on the fly.
1. Add a hotkey to the script to switch between two resolutions
2. Add a setup file or something you can edit easily to change the resolution
I found I could edit the Settings.fdb file to change the numbers to fit my screen. I switch from my laptop (1920 horizontal) to my monitor at work (3840 horizontal) and the script was correctly moving to the other side of the screen - halfway across my monitor. I can manually edit the fdb file (after using TaskManager to force Fastkeys to stop - I cannot reach the tray icon on my huge monitor with the numbers in the script for my small laptop screen) but I would like some easier way to swap numbers without have to force Fastkeys to exit in order to access the tray icon.
My case is a strange one and I can appreciate that. I figured I would ask for some direction - the script itself is working perfectly, it is my use case that is strange.
Thanks for any help anyone can provide!
