Hello
Can you start a program, then type tekst in 2 diffent fields og press enter, via a script i fastkeys?
Run a program
Sure, I do this all the time. Put something like this in the command field (Type=Command):
First check how many times Tab key needs to be pressed to get field focus.
Run, MyProgram ;change to your program path
Send, {Tab 3} ;sends tab key 3 times
Send, Text ;sends text
Send, {Tab} ;sends tab key
Send, {Enter} ;sends enter key
yes, you can add a sleep:
Sleep, 1000 ;miliseconds
You can also put all sends in one line, same example as above:
{1000} to wait 1 second
Run, MyProgram
Send, {Tab 3}Text{Tab}{1000}{Enter}
