Trigger Menu to OPEN, when a certain application is active.
GNS-Mississippi
Post by GNS-Mississippi » Nov 30th, ’23, 14:07
I am an inspector and use a Windows-based report writer called ScribeWare. I have several different menus to help me with repetitive tasks. They work beautifully. I use one specific menu that remains open while I write my reports, every time I open ScribeWare.
Q: Is there a FastKeys function that will auto-open a particular FastKeys menu when the ScribeWare software is active/open and then when I shut ScribeWare down on my desktop, the menu will be programmed to close?
Post by Marko » Dec 1st, ’23, 18:15
Currently not. But good idea, we'll see if something like this could be implemented in one of the next releases.
GNS-Mississippi
Post by GNS-Mississippi » Dec 2nd, ’23, 12:20
OK, thank you for all the work you do...
