Hello!
Please tell me how to convert the selected text to uppercase.
Upper Case
Search the Library, there is a script available - Convert text to upper.
Go into your FastKeys settings and do the following.
Shortcuts > New (+ Icon) > Library (Book Icon) > Command > Utility > Convert Text to Upper.
Then add in your custom shortcut and click "OK" to save. Hope this helps!
Here's some code from a couple default FK scripts.
I'll just offer them up here. Unfortunately, I'm not at the point where I can offer any insight - but I can just provide what I see here...
❶ | 'Capitalize Text if last character is CAPs' - is the Description provided | Shift + Alt + F12
CODE: SELECT ALL
Send, {Home}+{End}
Old:=Clipboard
Clipboard:=""
Send, ^c
ClipWait 1
Clipboard=%Clipboard%
char:=SubStr(Clipboard, 0)
if char is upper
StringUpper Clipboard, Clipboard
Send %Clipboard%
Sleep 500
Clipboard:=Old
❷ | [New Type: Command] | [Shortcut= Ctrl + CapsLock] | Description: Change Selected & Highlighted Text |
Menu Case, Add
Menu Case, DeleteAll
Menu Case, Add, &UPPERCASE, CCase
Menu Case, Add, &lowercase, CCase
Menu Case, Add, &Title Case, CCase
Menu Case, Add, &Sentence case, CCase
Menu Case, Add
Menu Case, Add, &Fix Linebreaks, CCase
Menu Case, Add, &Reverse, CCase
Menu Case, Add
Menu Case, Add, &Remove Spaces, CCase
GetText(Txt)
If NOT ERRORLEVEL
Menu Case, Show
Return
CCase:
p:=A_ThisMenuItemPos
If (p=1)
StringUpper, Txt, Txt
Else If (p=2)
StringLower, Txt, Txt
Else If (p=3)
StringLower, Txt, Txt, T
Else If (p=4)
Txt := RegExReplace(Txt, "((?:^|[.!?]\s+)[a-z])", "$u1")
Else If (p=6)
Txt := RegExReplace(Txt, "\R", "`r`n")
Else If (p=7)
Temp2 =
StringReplace, Txt, Txt, `r`n, % Chr(29), All
Loop Parse, Txt
Temp2 := A_LoopField . Temp2
StringReplace, Txt, Temp2, % Chr(29), `r`n, All
Else If (p=9)
Loop
StringReplace, Txt, Txt, %A_Space%%A_Space%, %A_Space%, UseErrorLevel
if ErrorLevel = 0
break
PutText(Txt)
Return
GetText(ByRef MyText = "")
SavedClip := ClipboardAll
Clipboard =
Send ^{vk43} ;Ctrl C
ClipWait 0.5
If ERRORLEVEL
Clipboard := SavedClip
MyText =
Return
MyText := Clipboard
Return MyText
PutText(MyText)
Clipboard =
Sleep 20
Clipboard := MyText
Send ^{vk56} ;Ctrl V
Sleep 100
Return
__________________________________
Hope this helps with a starting poing...
-S
CODE: SELECT ALL
Send, {Home}+{End}
Old:=Clipboard
Clipboard:=""
Send, ^c
ClipWait 1
if char is upper
Send %Clipboard%
Sleep 500
Clipboard:=Old
Menu Case, Add
Menu Case, Add
Menu Case, Add
GetText(Txt)
If NOT ERRORLEVEL
Menu Case, Show
Return
CCase:
If (p=1)
Else If (p=2)
Else If (p=3)
Else If (p=4)
Else If (p=6)
Else If (p=7)
Temp2 =
Loop Parse, Txt
Else If (p=9)
Loop
if ErrorLevel = 0
break
PutText(Txt)
Return
Clipboard =
ClipWait 0.5
If ERRORLEVEL
MyText =
Return
MyText := Clipboard
Return MyText
PutText(MyText)
Clipboard =
Sleep 20
Clipboard := MyText
Sleep 100
Return
-S
