http://cross-plus-a.com/bconsole.htm
This is the command in FasKeys:
Type: command
Send, ^{vk43} ;Ctrl C
Run, d:\Utilidades\Voice\Balcon\Balcon.lnk
In the direct access it is necessary to put:
Target: "D: \ Utilities \ Voice \ Balcon \ balcon.exe -c" (change program path to your own. The -c parameter is for you to read the clipboard) and change so that it starts minimized.
When selecting a text and using the assigned keyboard shortcut is already read, you don't need to use Ctrl + c. If nothing is selected, it reads what is on the clipboard.
A more elegant option, and that the CDM window does not start is using the Hidden star program. The FasKeys would look like this:
Type: command
Run, "Program Files (x86)\Hidden Start\hstart.exe" /NOCONSOLE /SILENT /D="d:\Utilidades\Voice\Balcon\" /MIN "D:\Utilidades\Voice\Balcon\balcon.exe -c"
My configuration is like this:
-b 1
-ka
-n Microsoft Helena Desktop
-a 20
-s 3
-p -10
-v 95
-tray
The following video explains everything (in Spanish):
https://www.youtube.com/watch?v=bpyM3yh6kk0&t
Suggestion for the creators of Faskeys. If calls are made to voice commands, I imagine that it is easy to implement this function in the program without needing the external program "balcon".
