Disable ac at certain places
davidp
Post by davidp » Feb 28th, ’19, 06:23
Disable ac at places like address bar,search bar of websites bcoz while typing url it's not necessary
JJussi
Post by JJussi » Mar 2nd, ’19, 08:46
How you think that fastkey knows that you are at "certain" place, when fk is just watching keyboard events?
JJussi
Post by JJussi » Mar 2nd, ’19, 08:59
You should select your auto complete strings carefully. I use (at the start of string) character what is never used at normal words. Like:
;ansi
;email
;msg
So, it's that semi-colon at that start of ac word. Normal typing have basically always space after semi-colon, so ac is not firing.
davidp
Post by davidp » Mar 4th, ’19, 06:39
Is this possible to add
davidp
Post by davidp » Mar 8th, ’19, 15:01
admin - give answer
davidp
Post by davidp » Mar 22nd, ’19, 08:29
pls give answer
Post by Tom » Mar 22nd, ’19, 14:53
This is not possible, sorry.
