increase or decrease brightness
davidp
Post by davidp » Feb 23rd, ’19, 16:18
change the default shortcut used for brightness because I'm using another app called flux and i can't use Ctrl + wheelup/down
Post by Tom » Feb 25th, ’19, 08:57
You can change the the default shortcut anytime.
davidp
Post by davidp » Feb 25th, ’19, 15:37
How to increase/decrease brightness by 3 or 5% or any other value
Post by Tom » Feb 27th, ’19, 08:34
I think you can change V variable in the script to something else.
