Feature Request- Option to set length of word to more than 5 in auto learning
sanchitgoyal
Post by sanchitgoyal » Feb 9th, ’19, 12:19
Hello
I would like to request a feature. Currently in the auto learning option the minimum length of word to be learnt can be set at 5 characters and not more than that.
I would like the option to set auto learning for longer words probably till 7or 8 as 5 length words are resulting in lots of words being saved which can be typed easily. Please add this option. Thanks.
Post by Marko » Feb 9th, ’19, 21:48
Sure, no problem, will be changed in the next release.
sanchitgoyal
Post by sanchitgoyal » Feb 11th, ’19, 10:35
Thanks
davidp
Post by davidp » Feb 14th, ’19, 04:49
8 is also insufficient,make it to 13 as words like characterized have many...
