Text expander
Stane2
Post by Stane2 » Oct 18th, ’13, 16:33
Hello, i think, in Fastkeys, you have one of the best text or phrase expanders around. I really like the convenience and wealth of options and I'm getting consistently great results. I see it as clearly the best program feature but still relatively hidden - you may want to think about giving text expander more prominent position in the menus, I think it should be on the first place. Just a thought...
Post by Marko » Oct 28th, ’13, 23:54
Thanks for your kind words. :D
Let's wait and see which modules will prove to be more popular than others. And you can always disable modules which are not being used.
