Disable all shortcuts?
thinman
Post by thinman » Aug 4th, ’13, 23:19
Hi, as many users (myself included) only use some functionalities (Start menu, text expander) but not the others, it would be great to be able to disable then completely.
I know I can just erase all the shortcuts, but it would be great if I could just disable it with one click.
Post by Marko » Aug 7th, ’13, 18:18
Yes, this makes sense. Please let me know what would be the preferable method:
- one click disable option on the main gui (for temporary pauses) or
- disable in Preferences - disabled screens would not even be shown.
thinman
Post by thinman » Aug 8th, ’13, 18:31
both would work for me. Maybe the best would be to make a choice in User Preferences.
Thanks for your great support.
Post by Marko » Aug 27th, ’13, 08:50
Hi Think, this will be implemented in the new release in few days.
thinman
Post by thinman » Aug 29th, ’13, 23:02
Thanks for today's update!
Great example of how the developer is listening to the customers!
