Having to reload
ehoyle
Post by ehoyle » Dec 14th, ’18, 12:21
Since the last update (I'm not sure if that is relevant), I've been having to reload FastKeys on starting my computer as it's not been working, even though it's there in the tray and opens when I click on it. But the shortcuts don't work until I reload it.
Please help, as I love this little program, but it's not much of a time-saver for me at the moment!
Post by Marko » Dec 14th, ’18, 13:23
This is most probably caused by another conflicting software which may listen for keyboard input and block the "keyboard hook", typically some anti viruses or software similar to FastKeys.
Have you installed such software recently? Try ensuring that FastKeys is loaded after such program or disable some of program's features which may cause the issue.
