export / import tab
ShadeBlack
Post by ShadeBlack » Jul 13th, ’18, 08:47
Hi there,
I know similar suggestions have been made, but I'd like to briefly weigh in... I would find it very helpful if I were able to share my auto-completes with a friend/employee.
This is particularly useful for writing the same code snippets throughout our projects.
It would be good if i could click on the whole autocomplete tab and hit export, give the file to my friend and they import the tab.
Post by Marko » Jul 13th, ’18, 21:37
Thanks for your suggestion.
As a workaround, you could save your settings to a new file (Save As...), remove all other items and send it to a friend.
