Multimonitor: Startmenu does not show on top edge
achseu
Post by achseu » Jun 18th, ’18, 07:19
i use a multimonitor setup. At home and at office. The startmenu is set to show up when i move the mouse to the top edge of the screen. This works fine as long as i don't install another monitor. But i did... FastKeys quits immediately reacting on mouse touching top edge. It continous showing up on a single monitor (not the primary one - seems to be random one) but on all other it does not show up anymore. I tried to reload, uncheck fullscreen option, use another option like bottom edge (same symptoms), rexstart pc - nothing works.
Does anybode have any ideas what i can do?
King regards
Achim
Post by Tom » Jun 18th, ’18, 14:10
Try aligning the top edges of your monitors in Windows Screen Resolution settings and then restart FastKeys.
achseu
Post by achseu » Jun 26th, ’18, 12:51
Yes, they weren't in a row. 'cause this is the reality.
