Use text key combinations
davidp
Post by davidp » Mar 11th, ’18, 13:07
@marko -- Add a shortcut to put the computer to sleep as a feature,instead of like a script
davidp
Post by davidp » Mar 13th, ’18, 10:23
@marko -- what's your answer?
davidp
Post by davidp » Mar 16th, ’18, 05:02
Another thing -- Say for example i have created a text expander shortcut to open a website,it open's the site only if Firefox is open or else it doesn't open.Fix this issue.
mike66
Post by mike66 » Mar 23rd, ’18, 09:10
I too have the same problem,it works only when firefox is opened
Post by Marko » Mar 23rd, ’18, 22:29
@davidp
We will add a sleep script posted by Tom to the Library.
FastKeys attempts to open a webpage in default browser. You can also specify any valid path like:
C:\Program Files (x86)\Mozilla Firefox\Firefox.exe "www.google.com"
davidp
Post by davidp » Mar 24th, ’18, 07:48
[quote You can also specify any valid path like:
[/quote]
Even after trying your valid path to open the website -- it's working only sometimes.
davidp
Post by davidp » Mar 25th, ’18, 08:05
Even in FK version 4.07 -- the valid path to open the website,is not working properly.
Post by Tom » Mar 25th, ’18, 10:33
Works perfectly well on all my computers.
You may try the following:
Type: Open
http://www.google.com
Type: Run
firefox.exe http://www.google.com
What happens if you run it via command prompt (Win+R)?
If this doesn't work, check your UAC settings or run FastKeys as administrator.
davidp
Post by davidp » Mar 26th, ’18, 02:36
I have tested several times if it's working,and it's working now but only if Fk is run as administrator.
Now the question is -- How should i start FK when windows starts with administrator rights.
davidp
Post by davidp » Mar 31st, ’18, 04:52
@tom sir -- Will the above issue be fixed in the next version?
