Please see the issue in video recorded screenshot here: https://imgur.com/a/BuAH7ij (make it full screen to see the text)
The TextExpander is changing the '\' character to a vertical bar, and my '1's to exclamation points.
When I insert the path:
"C:\AI\Environments\AUTOMATIC1111 stable-diffusion-webui"
into the InputBox, the output result is:
"C:|AI|Environments|AUTOMATIC!!!! stable_diffusion_webui".
[SOLVED] PATH variable not pasting path correctly
Sending keys to console windows (command prompt) can be tricky. One reason for this could be that FastKeys and console are using different input languages.
Here are few alternative suggestions:
- try changing your keyboard layout.
- use clipboard method (Preferences/Text Expander/Advanced/Use clipboard if text length exceeds... - set it to 1.
- use AutoHotkey script (Run command) for opening files/folders etc. instead
https://www.autohotkey.com/docs/commands/Run.htm
see examples #4
see examples #4
My quick, custom test worked fine with sending text from an inbox to a console. See the gif video: https://imgur.com/a/NJHxsjX
(I used this script to test: - My custom script is NOT WITH FASTKEYS)
I'm not trying to run anything from the text expander, only sending.
This worked! However, it's not sending {Enter} as a keystroke, but rather as a string: (I tried with and without spaces.)
p.s. Can you maybe allow embedding gifs in this forum, as we do with images? It would be easier to see a gif right here in the forums.
::]ai::
InputBox, OutputVar, , "path"
Send, %OutputVar%
ExitApp
With the clipboard method you need to use `n instead of {Enter}.
We'll check the forum software to see if we can allow animated gifs.
