Text Expander - Name Contains
I use the text expander display as you type, please consider allowing the ability to expand this functionality to work when typing letters that are contained within the word.
Example: If I type NBU it would show all of the following below because NBU is contained somewhere in the title name.
NorthNBUJava
SouthJavaNBU
NBUEast
Thank you...JGM
NorthNBUJava
SouthJavaNBU
NBUEast
Thank you...JGM
Currenty you can configure Auto Complete to show similar results but at least first characters needs to be right. We may consider what you ask for in the future.
This option has been added in 3.06 - Preferences/Auto Complete/Include words containing the string.
Marko,
Thank you for including this option, it is greatly appreciated.
I was at the office yesterday showing off FK, hopefully others purchase a copy.
Happy Holidays...JGM
Hi.
I use Fastkeys mainly as a text expander and the option “Include words containing the string” is *almost* what I need.
I use Fastkeys to insert RTF files inside ODT documents using the string to show the menu.
My Text Expander entries are like these (I'm just making this up):
When I type “-fund” or "-clas" the proper menu for text expander appears and works great.
With the “Include words containing the string” option enabled, if I type the word “java” both the menus appears as well.
However, most of the times when I type “java” I don't want the menus to appear and they end up appearing and being intrusive.
So I'd like that the “Include words containing the string” option would work only if the word typed is preceded by a prefix.
Lets say I want to show all the text expander entries containing the word “java” in the description.
Instead of typing only “java”, I would have to type “*java” instead (* as prefix).
This way, the “Include words containing the string” would work only if the defined prefix is typed before the word.
I hope I made myself clear.
Thanks.
String: -fundamentals1
Description: Fundamentals of the Java Programming Language
Type: Send
Substitute: %FILE_FundamentalsoftheJavaProgrammingLanguage_rtf%
String: -classes1
Description: Classes and objects in Java
Type: Send
Substitute: %FILE_ClassesandobjectsinJava_rtf%
Thanks.
I see your point. We can change this behavior to only match the abbreviation string and not the description.
Thanks for replying.
Actually I consider matching the description a great feature, especially if you have many abbreviations and don't remember them all.
I think matching only the abbreviation string would narrow it too much.
What I'd like to have is an option to match the description *but only if the word typed is preceded by a prefix* like "-java" instead of only "java".
Which prefix? You mean to have * as a fixed search prefix?
The idea of a fixed search prefix would work for me.
It could be *, it doesn't matter. The important thing is that the prefix would indicate that the program should match/search the descriptions.
I'm certain that the current option “Include words containing the string” is very useful to a lot of people and it should remain.
However, for me it returns results all the time because I have dozens of text expander entries with long descriptions.
So it would be nice to have an option to trigger the description search only if a fixed prefix is used.
Maybe I have a very specific need because I use Fastkeys mostly as a text expander to paste long excerpts of RTF text. So I understand if the suggestion seems useless for most people.
We can implement * suffix instead of prefix. Typing "java*" would show all strings and descriptions containing word "java".
