Text Expander - Sort
JGM22
Post by JGM22 » Dec 23rd, ’15, 18:35
Please consider providing the ability to sort the text expander items by maybe adding a sort to the context menu, currently reordering is a manual and cumbersome process.
Thank you, much appreciated as always...JGM
Post by Marko » Dec 23rd, ’15, 22:08
Thanks, will be considered. ;)
JGM22
Post by JGM22 » Dec 23rd, ’15, 23:10
Marko,
Thank you for the consideration, much appreciated as always...JGM
dougbrian
Post by dougbrian » Sep 9th, ’16, 00:53
Definitely! Really could use that. Thanks.
Looks like this great idea was submitted three years ago. Uh-oh.
Post by Tom » Sep 9th, ’16, 01:14
Column sorting is available already from version 3.07. Enable this feature in Preferences, then click on column heading to sort.
thepipe
Post by thepipe » Mar 3rd, ’17, 19:39
The column sorting function does not seem to extend further. For example, items in a phrase file are presented in 2 columns, but clicking the column headers does nothing - even when column sorting is turned on in preferences.
It would be very helpful if column sorting applied in all instances where columns are displayed.
Thanks for your consideration!
Post by Marko » Mar 5th, ’17, 16:28
Thanks, we can add Phrase File/Wordlist sorting feature, of course.
Language Wordlists (like English Common Words etc.) contain words sorted by frequency of occurrence - in this case user would have to be careful with the sorting.
