I would appreciate help, since there is an "auto complete" error when inserting some words beginning with #
For instance, this a list loaded in Fastkeys:
#following screencast the issue is detailed:
#drag&drop
#screenshot
#shortcut
#thank you
However, words all the other words are inserted without having the first letter (e.g. creenshot, hank you), and also trigger some global shortcut from Windows since some screens just pops-up.
I recorded my screen detailing the problem: https://goo.gl/2wyqpt
How to make "auto complete" to insert the words above with no errors?
Thanks,
Carlos
