Correct Double Capitals delay
mcrew
Post by mcrew » Sep 20th, ’16, 18:04
The Correct Double Capitals function has too long of a delay. It tries to correct the double capital on word 1 while I am typing word 2, resulting in errors with word 2. Let me know how to adjust this function so that it works quicker.
Post by Marko » Sep 21st, ’16, 11:16
Hi, I tried on few computers and I had no issues. Do you use some specific settings (Key delay...)?
mcrew
Post by mcrew » Sep 21st, ’16, 18:23
Under Text Expander, the Key Delay setting is 0. The Paste Delay was 50ms, I will change it to 10ms to see if that makes a difference.
A common problem from the delay is when I want two words to be capitalized (e.g., first and last name). FastKeys is automatically removing the capitalization from the second word.
Post by Marko » Sep 22nd, ’16, 10:09
Sorry, I cannot reproduce your issue. The feature prevents the second character in a word to be uppercase and sends it as lowercase instead. There is no backwards correction. Are you using English keyboard?
mcrew
Post by mcrew » Sep 22nd, ’16, 17:41
Using English keyboard with Windows 10 (latest version).
Problem continues to happen regardless of Key or Paste delay setting.
Once I disable the CDC function, the problem ceases.
Post by Marko » Dec 12th, ’16, 05:57
Strange, could you check on another computer?
