Show a visual indication when a gesture is drawn.
krushna
Post by krushna » Oct 12th, ’16, 18:32
Show a visual indication when a gesture is drawn, with these features --
1.ability to select the thickness of the gesture drawn in pixels and a custom color for it.
2.minimum gesture length.
3.opacity
4.which mouse button to be used
Post by Marko » Oct 12th, ’16, 18:37
Check Preferences/Mouse Gestures - suggested settings are already available.
krushna
Post by krushna » Oct 12th, ’16, 19:10
I saw the settings --
I have enabled show mouse trail -- even then it' showing gestures sometimes only and not always. (it's a bug)
Guest
Post by Guest » Oct 12th, ’16, 19:29
Update -- and i get the indication sometimes only, if the trail width and color setting is above 6.
Post by Tom » Dec 12th, ’16, 03:02
You probably need to reset Preferences to defaults.
