"switch" to google chrome instead of start 2nd instance
Thomas
Post by Thomas » Dec 7th, ’16, 12:49
I like to switch to a running chrome session by e.g. pressing "ooo" (like the calc example).
If chrome already is running, I like to switch to it at the present tab-folder.
If chrome is closed - simply this shortcut should start chrome.
In the moment I don't have a good idea.
normally in a batch I would check the running tasks.
How is it possible by ahk?
br - thomas
ChrisKey
Post by ChrisKey » Dec 7th, ’16, 15:03
I use something like this...
THEapp:="Total Commander"
IfWinExist, %THEapp%
  IfWinNotActive
     WinActivate
  else {
		WinGet, numCountWindows, Count, %THEapp%
		if (numCountWindows>1) { ;more than one open window -> cycle
			WinGetClass, ActiveClass, A
			WinSet, Bottom,, A
			WinActivate, ahk_class %ActiveClass%
		else {
			WinMinimize
else {
	run C:\...\TOTALCMD.EXE
This script does a little bit more than you asked for.
I use it for every application that I start frequently.
If the app is not already started => it starts the app.
If the app is started but doesn't have the focus => brings the app to the foreground.
If the app has the focus and there are more than one window of this app => it cycles through the open windows.
If the app has the focus (only one window) => it minimises the app.
Post by Tom » Dec 7th, ’16, 20:05
This works for me:
String: ooo
Type: Command
Substitute:
IfWinNotExist ahk_exe chrome.exe
   run, "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe"
WinWait, ahk_exe chrome.exe
WinActivate, ahk_exe chrome.exe
You may need to adapt the Chrome path to your Windows version.
Ennovy
Post by Ennovy » Dec 8th, ’16, 09:00
  IfWinNotActive
     WinActivate
  else {
			WinSet, Bottom,, A
		else {
			WinMinimize
else {
I use it for every applikation that I start frequently.
Thanks, I can use this.
