Language Keyboards conflicting with FastKeys
MJB
Post by MJB » Nov 15th, ’21, 20:55
I know this is a fairly specialized issue but I'm going to throw it out there.
I frequently type using another language keyboard and switch back and forth between it and English. To make this easier, I use commonly used program for linguists called Keyman by Tavultesoft. (https://keyman.com/windows/) When I use it, FastKeys' text expander function basically stops working, which isn't ideal because I commonly use text phrases when I'm needing to switch languages.
Are there any users of both these programs out there that have found a way to have them work in conjunction.
I'm using Windows 10, Core I7 processor, 16 Gb RAM.
Interestingly, on a side note, it does cause an unusual other glitch. When both Keyman and FastKeys are running, typing a "c" will cause the calculator to run.
Any help would be appreciated.
Post by Tom » Nov 15th, ’21, 21:12
Does language changes work if Keyman is disabled? If yes then this application prevents Fastkeys keyboard hook. Try running FastKeys after Keyman.
