Clipboard manager - clear all
Ennovy
Post by Ennovy » Jul 28th, ’16, 07:58
In my preferences the clipboard history size is set to : 20
My questions:
1. All data copied to the clipboard is kept only in memory or also in a file (couldn't find one)?
2. Sometimes I need to clear all (or some) of these entries.
Is there an easy way for you to add this option to FK? Right click on an entry to delete the entry or all entries.
Would be very nice.
Thanks for your support an for making FK
Have a nice day.
Post by Marko » Jul 28th, ’16, 13:38
Hi Ennovy, clipboard data is only kept in memory and the easiest way to clear all entries is to reload FastKeys - you can even create a shortcut for this in Preferences/General/Shortcuts.
We may be expanding the options in future releases.
Ennovy
Post by Ennovy » Jul 28th, ’16, 14:08
Thanks Marko, I did not think of that option. I will use the shortcut.
