Open-Save-Dialogue jump to Folders
HerbHert
Post by HerbHert » Aug 12th, ’21, 18:51
Would be great if Faskeys could do this:
When I open a open/save-file dialogue lets say in Word and start at the same time the Fastkeys start menu with my favorite folders - I could click to a folder and - whooom! - the open-save-dialogue jumps to this folder ...
mragtronx8
Post by mragtronx8 » Aug 14th, ’21, 20:10
HerbHert wrote: Aug 12th, ’21, 18:51 Would be great if Faskeys could do this:
handy feature, would be great to have it
Post by Tom » Aug 15th, ’21, 09:18
You can simulate the keystrokes - learn about this technique in our instruction video
https://www.youtube.com/watch?v=kZeh52QL9UM
This presses Alt+F to open the File menu, A for Save As, B to open the Browse dialog and then pastes the folder path. Tested in Word 2013.
!f{200}a{200}b{300}D:\Temp\MyNewFile
You may need to adjust the pauses. You can also use a Selection Form macro for a path selection.
!f{200}a{200}b{300}%SELECT_Path%
