html link insert
abscaps
Post by abscaps » Sep 17th, ’20, 06:52
I am trying to use a text expander to trigger a popup box for me to insert an href tag and link text. However, I'm having problems as it inserts a space before the url and extra </ before the end tag like this.
<a href=" url.com">keyword</</a>
The macro also causes my shift key to lock on down.
Attached is screenshot. Can you let me know what I'm doing wrong? Thanks.
Post by Marko » Sep 17th, ’20, 18:19
I tried and it works for me.
Probably there is another similar text expander active - try to disable it or change the abbreviation to something else.
abscaps
Post by abscaps » Sep 17th, ’20, 20:56
Ack! I found the problem. Fastkeys was conflicting with another Textexpander I was using. I'm migrating to Fastkeys so I was still using the old one. Thanks.
