Use phrase file in start menu
procrastinator
Post by procrastinator » Jun 4th, ’20, 20:39
The help file under "Using Fastkeys>Modules>Start Menu" says that Phrase File is available as a command type (under 2 Select command type) but this option is not made available on the menu item setup form. Can this option be made available please?
Post by Marko » Jun 5th, ’20, 12:07
Phrase files are a groups of simple text expander phrases and can only be used in Text Expander module.
We will correct the documentation - thanks.
procrastinator
Post by procrastinator » Jun 5th, ’20, 13:27
Thanks Marco
