Blacklist for learning function
kr72
Post by kr72 » Nov 1st, ’14, 05:32
The learning function learns unfortunately my passwords. Can not you ard a black list integrate with the words that should evaluate not learned, for example, with if the word begins with a certain letter combination is not the word to be learned. Then not possible to save this black list in plain text.
Ennovy
Post by Ennovy » Nov 1st, ’14, 09:03
Goto Preferences/Auto Complete and there you find Not active in
Here you can add applications where you don't want to use Auto Complete
Also works for Auto learning.
kr72
Post by kr72 » Nov 1st, ’14, 16:16
Unfavorably the whole program is so useless because he learns the passwords in the browser and in the browser I need the autocomplete most. a black list with the words start over from xxxx not learn would be better.
Post by Marko » Nov 2nd, ’14, 20:17
We have tried to automatically detect the password field but was not reliable enough. Therefore thanks for your suggestion, we will add a list of "blacklist" strings. Any words which would contain one of the strings will not be learned.
Post by Marko » Nov 12th, ’14, 19:40
Introduced in 2.19
