Can you please check the following topic.:
Setup: 2 monitors (A & B)
I open Fastkeys setting window via KeyShortcut on Monitor A.
and close it.
Then I move the mouse to Monitor B
Open again the setting window (independen if Hotkey or Mousekey).
The setting window openes on Monitor A - instead at the mouseposition
kind regards
albatross
Setting window opens not at mouseposition on multimonitors
This is expected behavior. Settings window opens at the position it was last closed.
Would it be possible to add an option to click on, if I want to open FastKEys at mouseposition or not ?
This would help a lot - as I'm using multimonitors - and it would keep me time.
(And if not ? - Is there a possiblity to create AHK-Script, that changes the behaviour and open FastKeys setting at the mouse position?)
Thanks in advance
Thanks in advance
