Macro > Input Selection Form > CheckBox > Is there a character limit to the "Selections" section?
SYN
Post by SYN » Jun 19th, ’19, 05:21
It seems that if the options are too long, the Checkboxes just don't appear at all once I fire the String.
Kind regards,
SYN - Melanie
SYN
Post by SYN » Jun 19th, ’19, 05:52
I'm trying to use this for Input Selection Forms with CheckBoxes:
Label:: - Full text sentence element
Label2:: - Full text sentence element two
But once I select these and fire them, it just expands "Label" and not "- Full text sentence element".
Am I doing something wrong?
Kind regards,
SYN - Melanie
Post by Tom » Jun 19th, ’19, 08:10
Currently CheckBox is the only control which does not support description labels.
The limit should be around 1000 characters per selection - how long are your selections?
You can also send your example file to our support mail and we will check.
SYN
Post by SYN » Jun 19th, ’19, 09:57
Thank you, I've sent an email!
Kind regards,
SYN - Melanie
