Macro > Input Selection Form > CheckBox > Delimiter (Last) cannot be removed
SYN
Post by SYN » Jun 19th, ’19, 05:20
Macro > Input Selection Form > CheckBox > Delimiter (Last), specifically the value of the first textbox (,) cannot be removed. Once I hit OK, OK Apply and go back into the Input Selection Form Dialog, the "," is back.
Is there something I can do to remove that permanently?
Thank you in advance,
kind regards,
SYN - Melanie
Post by Tom » Jun 19th, ’19, 08:11
I see, thanks for reporting, will be corrected asap.
SYN
Post by SYN » Jun 19th, ’19, 09:42
Thank you very much!
