Hi!
I have two monitors (side by side)
1. 3440x1440
2. 2560x1440
Preferences - Functions - Volume "Control with mouse wheel on right screen edge" is enabled.
Now the problem is that this "right edge" is at monitor 2 at point of 1/4 of the screen!!! So, if my cursor is at area of (X) 640 - 2560, scroll wheel changes volume and don't "roll" web page under it.
Is there (in the code) somewhere fixed that, if mouse X position is more than 4000 (or something like) it "must" be at right edge of the screen?
Wheel volume control problem.
Have you reloaded FastKeys after changing monitor setup?
Actually no...
That must be reason. At home, I have 4K and at the working place I have that "wide" setup... Machine has been booted last time at home.
..and that will "explain" all other "screen edge" problems.
Because computer is laptop, screen size vary.. Some times it's just it's own FullHD display, sometimes external 4K, Multiple big monitors OR combination of some of those.
I would be nice if fastkeys could "hook" itself to screen size change event and when screen size change, it would "fix" internal information of screen size (and edges).
