Pasting text within characters
Oblomov
Post by Oblomov » Mar 8th, ’19, 20:51
I'm trying to paste some text into asterisks with
clipboard := clipboard
Send,% "*" ClipBoard "*"
But instead of
*text
text text text
text*
I get
***text
text text text
text
Is there any way to fix my command perhaps?
Post by Tom » Mar 8th, ’19, 23:09
Some editors treat `r`n (CR FF) as one break, others as two. Try this:
clip:=clipboard
StringReplace, clip, clip, `r`n, `n, All
Send, % clip
Oblomov
Post by Oblomov » Mar 10th, ’19, 13:38
Tom wrote:
Mar 8th, ’19, 23:09
clip:=clipboard
Send, % clip
I see.. although, where would I put in the asterisks?
Post by Tom » Mar 10th, ’19, 19:48
Send, % "*" clip "*"
Oblomov
Post by Oblomov » Mar 10th, ’19, 21:52
Awesome! Thanks! :)
